replacing engine mounts (XU92C)
- amilo123
- Modèle(s) 309 : GT
My engine is vibrating at idle, not much, but I saw that engine mounts are cheap and I would like to replace one of them myself. I am talking about the one on the left side of the engine, the one at the top. Is it hard to replace? Could I do it myself? I think that this engine has 3 of them right (2 more on the bottom)? Would it make any difference if I changed only this one?
Re: replacing engine mounts (XU92C)
If I'm correct, you just need to lift the engine in order to replace it.
It is easy to replace but when your engine vibrates, it is generally due to the one in the bottom, near the right "gimbal"
- amilo123
So should I leave it alone then?thefunkyboy a écrit :It is easy to replace but when your engine vibrates, it is generally due to the one in the bottom, near the right "gimbal"
Could you take some picture? Generally, the one near the gearbox tells you if you need to change them or if it is not hurry.
